Topping F-105 Restore Project
Re: Topping F-105 Restore Project
Postby solumis » Mon Jan 18, 2010 5:10 pm
uhh not also toys ... i like to watch all the toys and tin stuff but not collectin them i just have some Dinkys ;)
Postby MichaelB » Mon Jan 18, 2010 5:13 pm
Do not dismay!
Posters in this forum have a lot of enthusiasm that spills over into all areas!
I love your big metal 105s and am jealous of you....keep the reports coming!
Postby solumis » Mon Jan 18, 2010 5:41 pm
the truth is... i just don't not have enough space for getting into toys
Here now the rest of the F-105's
The large plastic Topping/Precise with vietnam camoflage F105 have now also the correct arrowhead stand
The small camo is from Precise
The metal 1:50 is a Verkuyl F-105 - with the wrong stand, it is the precise stand - the topping/verkuyl was the black one
1:50 metal Verkuyl
1:50 Precise or Topping
small (1:200) plastic Precise
Postby grwebster » Mon Jan 18, 2010 8:08 pm
Now I understand you limitations on collecting space, solumis, after having seen the size of your German BAC 1-11 on the other post.
viewtopic.php?f=12&t=354&p=1087&hilit=Bac#p1087
Incredible, do you have other that scale?
I had a french collector tell me he had a 6 meter {18++ feet} long Concorde model in his basement. Turns out he did. After he died it was given to a museum.
Postby MichaelB » Mon Jan 18, 2010 8:28 pm
Wouldn't 3 meters be only about 9-10ft? Still, a big one...they are always impressive but usually lack detail to the same level. The Frontier of Flight Museum at Love Field in Dallas (KDAL) has an excellent collection of these big birds.
Here's one from our collection...not quite a Concorde but just an SST. It came from Continental so it has to date from 1968 or so. It's only about 6 feet long and a real beauty!
Any speculation on the maker? Maybe Blaine again....
Continental SST.jpg (105.6 KiB) Viewed 4593 times
Postby grwebster » Mon Jan 18, 2010 10:01 pm
meant to type 6 meters, i corrected it.
Postby BoeingDriver » Mon Jan 18, 2010 10:13 pm
Andi--your Thud collection just keeps getting better and better. I still am impressed with your Republic casting.
Michael--My guess is Pacmin on your SST. I've seen a number of those done by Pacmin with the old style sticker. Of course I could be fooled by the photo so you may have to send it to me for positive ID :lol:
Ladd
BoeingDriver
Postby MichaelB » Mon Jan 18, 2010 11:09 pm
Come inspect it yourself! The Museum is at KHOU...welcome anytime...would love to get a positive ID...
Postby BoeingDriver » Fri Jan 22, 2010 1:07 pm
This thread has been remarkable. I have to thank the guys who helped out with this project. sosliptream and michaelb for modelling techniques. Solumnis for a file scan of the correct decal and some contact information for Mark Johnson. I contacted Mark and he sent me partial decals which was all he had--he said they were better off on a model than in his decal box. Nice guy. Check out his website-- http://precisemodelsllc.com/default.aspx
That said I have another question: When you talk about coating old decals with lacquer what is it you use and how much do you apply?
Cheers,
Ladd
BoeingDriver
Postby soslipstream » Fri Jan 22, 2010 1:57 pm
Ladd,
As an opinion, and making some assumptions....
1) If you are covering with old decals, before[i] removing[/i] the decal from its sheet, then I would use a Krylon Clear Acrylic Satin Clear or even Krylon Clear Acrylic Coating (slightly heavier). A laquer such as Deft Clear Laquer will work but sometimes does not keep a brittle decal intact.
2) If the decal is fresh,can be water soaked and applied intact, then, when dry, a thin layer of laquer should work fine. If it can be applied with an airbrush, all the better, The idea is to preserve the decal and protect it from minor abrasions.
Good Luck,
